13inch Cobra Brake Group buy :
FYI this "Group Buy" is still going currently up to 8 participants including myself and the OP. We need 10 to get this going so if you'd like to join in now's the time to do it. Once we hit 10 there will be a $200 deposit required from each participant before production starts, with the rest due on completion and before the parts will be shipped.
The kit is $425 and includes the following:
1 Pair of hubs machined from new OE rotors
1 pair of brackets machined from 6061 T6 billet aluminum
To give a little more information this is a kit to mount 03-04 Mustang Cobra 13" Rotors and calipers on the front of any 2wd 95-03 Ranger or Mazda. It will also fit on any 83-94 Ranger which has been upgraded to 95-97 spindles. The hubs are available with tone rings, so if you have 4WABS it can be retained.
I'd also like to point out that the kit is only the hub and caliper bracket required to mount the Cobra rotor and caliper. You have to source your own caliper, rotor, brake lines or anything else that may be needed.
