whisperer
My original posts are gone on this problem that told the whole story. Don't know what happened, I'm back to 0 posts, my profile is gone and I seem to be "Reset". Anyway....
I had been having this really crappy running problem where after engine warm up I would lose serious power on the highway. My milage went totally to heck - 11 MPG on a good day. When I bought the truck I was getting about 20 MPG.
The computer kept throwing Code 41 for Oxygen sensor so I replaced that, checked the wiring all the way from the O2 sensor to the Computer and ended up replacing the ECU anyway because I had a known good one. Still throwing code 41. Arggg.
I did all the other normal checks, actually went over everything that I could think could possibly be the problem. Nothing made any difference, Code 41. I did check the fuel PSI during all that and it was good, at least in the shop on my gauge.
OK, the solution. I CHANGED THE FUEL PRESSURE REGULATOR and all the crap went away. I'm posting this in order to try to help somebody else to NOT have to screw around for 2 months trying to find the problem. Note: There was no sign or any indicators pointing to the FPR in this whole scenereo. I guess if I would have hooked up my PSI gauge and clipped it to the windshield and drove until it occured I might have seen something. I should have, I didn't.
Another note: a friend also had the same symptoms on his 4 cyl and I told him to change the FPR and it also fixed his so it's not 2.9 specific.
