f1502rngr
- Jul 28, 2008
- Automatic
I just wanted a plain jane inexpensive system with little bass. I bought a sub box that would fit my 98 Ford Extended Cab F250 under the bench seats. My amp is a Total Mobile T3202 and I bought some simple speakers that a friend actually had in his truck and sounded decent enough for me, they are from Pep Boys, 10 inch SPX Subs single voice coil. I installed the speakers and then took 16AWG speaker wire and connected them in Parallel to get 2 ohms. I tested my amp on my sons car because his car is wired for a serious setup so the power/ground/REM and RCA cables were there for me. I started out low and they sounded great, but when my son went to vol 10, his 40amp fuse blew (the main wire fuse at the battery end), I thought it was the amp, so I reconnected his amp (a Rockford\Fosgate) and disconnected his speakers and connected mine, replaced the fuse, then everything is great until vol 10, the main fuse again!! So i reconnect his speakers back up and replace yet the fuse again, vol 10 nothing, vol 20 I am screaming to turn it down, all that bass!!!! Should I just wire these subs individually and not bridge the amp? I just want slight bass to where there is a nice sound system in my truck.
Thanks!!
Thanks!!
