In the process of building a 88 Bronco 2 that has a 302 with a T18 and NP205 transfer case and swapping out the stock running gear for a front 14 Bolt and rear Dana 60. Eventually a 3 link front and 4 link rear.
yeah I know.... the 14 isn't a steering axle, the 60 is. With enuff money one could fab up any form of convoluted abortion imaginable, the question is why? Just do it the easy way, you will be up running much faster and with moe bux in your pocket for gas. JMNSHO. Carry on.
14 bolts makes a hell of a front axle... I've seen several 14 bolts made into steer axles. Might be helping to build one soon.
it's kinda "different" to pair it with a 60 rear tho. Most people do a 14 bolt front and rear or a 14 bolt rear and a 60 front. No big deal tho. JUST ROCK IT!!!
For
