1" body lift installed
sonic04edge
Madison, AL
1998
Went over to Josh's(HozII) last sat and we got my BL installed. Sits perfect now. I will be getting a buddy to make me a bracket to bring the front bumper up and also a custom tube bumper for the rear here in the next few weeks.
Before:
After:
In this picture it shows how much the 1" shifts the cab. Also the bed was already done in this pic.
where did you get and what brand is that body lift? thats just what i want. all i can find are 3" body lifts. looks SICK!!!
Thanks man. Unfortunately I dont have any info on that. I bought it used from a member on ranger-forums. From what I can tell the 1" for rangers were discontinued.
I've been looking for a 1" body lift, but can't find one. Might have to get a 3" and cut them down.
A friend of mine bought 1" body lift spacers on eBay for $1 each then bought some longer bolts. I think it cost him like $40-50.
Nice truck man.
shit, that sucks. for me anyway.
if that works out for you post it up. i just want a 1" lift too. it'd be perfect for fitting 31's on my truck. good luck.
Nice truck man.
that sounds like an idea. I'd need something with instructions and what you're talking about sounds like a universal thing. maybe ill "search" for 3" body lift instruction's and substitute everything with the 1" spacers. sound like a good idea or what?
thanks
thanks
There may be something in the Tech Library, I know there are instructions for some Suspension lifts in there. Body lifts are pretty simple though... You just undo the body and bed mount bolts, put in the spacer and install the longer bolts. With 1" I don't think you need shifter or steering extensions, either. You may need to check the steering shaft and slide it out a bit though. The friend I mentioned put the spacers on his Yota in like 2 hrs.
it wouldn't be nothing to cut a 3" down mine is a hardend plastic a sawzaw would cut it.
I'm not a fan of flare side trucks, but I'm diggin yours. Looks nice and the b/l helped the stance for sure.
Cutting them
I would use a metal cutting chop saw. They are plastic and solid throughout. They would cut clean with a chop saw.
