1-3" Torsion Keys and 1.5 Blocks. Too Much???
JDanger
I have a 2003 FX4. I see Supreme Suspension has a kit that offers 1-3" keys and blocks in heights from 1", 1.5", 2" and up. If I put 1.5 blocks in rear and use the 1-3" keys in front to level it out, do you think that would put too much angle on the front stock suspension to cause problems? I want to move up to 265/75/16's and want good wheel well clearance. I am going to jack it up to the desired height and check front CV's to have a look but wanted some opinions.
You should be fine. I cranked my torsion bars up about 2 inches with no problems except worn shocks, and adding torsion keys is just fine. All you have to do is get an alignment.
