06 2.3L Face swap questions
angrywrench
Long Island, NY
I have a 2006 2.3L that is basically your standard utility truck. Basically bought it off Time Warner Cable's fleet lot. I wanted to change the grill to that wire mesh looking style that the Sports(?) have and change the god awful front bumper to something slimmer. Can't seem to find anyone on youtube or whatever that has decent info, maybe I haven't looked hard enough. Also trying to change the wheels to something a little bigger but not so big that it looks stupid, but I'll spare you all another "biggest tire for a stock ranger" thread. Thanks in advance.
I have a 2005 like yours, a basic fleet truck, manual transmission, 3:73 rear gears.
bought new, currently about 367,500 miles so I've had many sets of tires on it.
both acceleration AND braking will be noticeably affected by larger tires.
245/70-16 was too much for me, 235/75-15 was OK,
currently very happy with 235/70-15 performance wise.
if yours is an automatic the 4.10 rear gears will help with acceleration, but the auto won't help any with braking.
the 245/70-16 were about 29.5" on stock offset and fit with no issues/rubbing.
I can guess at what grill you have, but can you provide pictures of what grill you want? That would help a lot indetermining what you need to do to get it. Same for the bumper.
There were a few variations of Ranger grill that had a mesh style and they take different components to install on your 2006. I'm not entirely sure what you mean by "slimmer" bumper, but again there were a few different styles and they take different components. It's possible to install any combination (98+ parts) on your truck, just a matter of knowing what else is necessary to make it fit. Maybe hood or fenders, maybe header panel or headlights.
FWIW I'm wanting to restyle the front of my 99 too and it'll take replacing basically everything except the fenders to get the look I want.
Bigger wheels or bigger tires? Is the goal a taller ride height, less open space in the wheel wheels, or just bigger wheels?
You can definitely run taller tires (I can't give sizes), but as noted you need to take it into account in braking allowances. If you're just looking for less open space, have you considered mildly lowering the truck? IMO it's a better and better looking solution for that than taller tires.
You can run bigger wheels without changing anythng else, you just need to determine the proper tire size to match the diameter that is there. Or you can run bigger wheels with either a taller or shorter tire.
Picture is worth 1000 words. Have you got a photo example of a Ranger with the styling you are after?
