LowRanger_96/05
Does anyone have a preference on motor mounts/conversion kits for a mid 80's 302 going into a 2005 2WD ranger? I have a 96 ranger with a 302, but the kit is different...
There were 2 different 2WDs made in 2005, so there are two different answers.I have everything i need to make the truck run (i.e. wiring, fuel lines, exhaust, ext... ) but the motor mounts that come stock in the 05 are very high, and will put my 302 through my hood. The current kit that i have (two steel plates mounted the the engine cradle that bolt to my motor mounts) will not work with the newer style frame. I need to know one of two things; what motor mounts will work with the late 80's 302 block so that the engine sits low in the frame, or if there are any kits anyone has used to replace the stock mounts.
Just kind of wondering what wiring and computer you are planning on running? Torque Monster headers? Reason I'm asking about which computer is that the '05 is a real odd ball, doesn't come with the PAT's system. Been wondering if the '97' Explorer would work but never got around to checking out all the pin connections.I have everything i need to make the truck run (i.e. wiring, fuel lines, exhaust, ext... ) but the motor mounts that come stock in the 05 are very high, and will put my 302 through my hood. The current kit that i have (two steel plates mounted the the engine cradle that bolt to my motor mounts) will not work with the newer style frame. I need to know one of two things; what motor mounts will work with the late 80's 302 block so that the engine sits low in the frame, or if there are any kits anyone has used to replace the stock mounts.
