black_demon69
it is a 4cyl 2wd front coil IFS suspension question is if the ball joints are tight with no play and wheel bearings also have no play aside from alignment could it be weak coil springs causing camber issue?
weak springs would also give you noticeable drop in ride height if they are so bad as to affect camber.
how many miles?
what do the bushings in the control arms look like?
my 2005 2.3 reg cab has 322,000+ miles on the original coil springs and lower control arms., no problems with ride height. lower ball joints, upper arms, camber adjusters were replaced 4-5 years ago at about 180,000 miles.
If your talking about the tops of the tires being inwards, I've never seen a ford rangers front that wasn't like that, ever.
Sent from my SAMSUNG-SM-G890A using Tapatalk
