0446 code
ranger2007
Hi Ok here is problem have 2- 0446 codes showing on scanner. Changed both electrical solenoids , the 1 under hood other mounted on canister also changed the canister . So what"s left ?? If I clear codes ( or supposedly cleared codes ) the engine check light goes out and stays out until you shut off engine and restart. Then engine check light comes back on. also with engine check light out the scanner shows 0446 code but light is out. So totally stumped ??? Thank You if you can help 2007 4.0 engine 156,000 miles runs excellent best truck I ever owned So please help Thanks again
