Wanted 04 Supercab 4x4 frame
tasker
granite state
looking for one...will be in NC in April...anyone along the way from NH? looking for a clean one....thanks!
Might can help if you're willing to drive all the way to Alabama. Do you want a completely bare frame or one w/ suspension components?
I live a little south of you here in Alabama. I could use a good frame and a 4 door cab if you are parting out a truck? Let me know.
Thanks
I have access thru two friends (B & B Motors) to about 15 Rangers, mostly 90s, up to about '07 or '08, all damaged in some way. They are not active junkyards but will sell stuff. Give me more detailed info (year, color, 2w, 4w, etc. ) & I'll see what's available.
rangers
I have an 03 super cab 4wd that came from rusty acres. I replaced the rear frame and bed a couple of years ago. The frame I have is solid but is pitted and is rough.
I would like a good rust free frame with front suspension, and a 4 door cab along with some other trim pieces. Color doesn't matter. It's getting stripped and painted most likely anyway. The interior I need is grey. But if the interior is another color, I'm sure I can pull what I need from another truck. I might consider the whole truck for the right price. I'm near Cullman, AL. B&B appears to be close by.
After I finish up the diesel swap and work out the bugs, I'm going to transfer everything over to a solid frame and basically work a frame off restoration.
Thanks for the help.
I'll check Mon or Tues. Two separate yards, both near Baileyton. NOTICE: They tend to be pricey.
FYI: Joey Brock between Cullman & Welti will be cheapest because he turns stuff over quickly.
Tasker,
Spotted a couple frames that should meet your needs but all the way to N Ala.
THANKS but probably a bit too far from where i will be...still looking!
I have a 98 ranger with a good frame on it in nj
Do you still have this access? I need a replacement cab with 4 doors & L fender (preferably Torreador - FL) that will fit an '03 XLT. Also RHF glass, LHR glass, & sliding rear assembly. A windshield would be nice, too, but those are easy.
I'll check. Don't know of a good 4dr cab, maybe some of the smaller pieces.....................
