04 ranger
Scottdale PA
if i crank my tb's or use the keys, and add a 3" body lift will 35" tires fit,& can you put 15" rims on a 04? i have a set of 15x8 wheels off my 83 i sold will they clear the rotors & calipers on the front :dunno:
No. 35's require a 4" suspension and a 2" body lift.
Most 15" rims will fit. Late-model base XLT 4x4's come from the factory with 15's. Some won't however, so it's best to try them first.
The 15" wheels will fit on any '04 Ranger.
33x12.50 will fit with a body lift and torsen bar cranking.
so 35"s will fit with a 3" bodylift & 2" torsion bar crank. ill have to put the 1" blocks on the rear for level front & rear rite?
another ? if i crank the torsion bars to 2" will it set level or will i have to put a bigger block in the rear
the crank makes it pretty much level. you only need blocks if you upgrade the front suspension. (at least on mine it did)
cool thanx, btw what size tires u got on there? im gona put 33 12.5 15 on mine here shortly,( and a body lift ) cant wait, did u have to get a alignment after the crank?
35's fit with MAXED torsion bars and 3" BL. But it ain't fun and I wouldn't wheel it...and I wouldn't run flares. And i'd trim the valence quite a bit. ANd when you get that big with tires, you really should start thinking about gear swaps. I would know too....ran that setup for a few weeks before the Superlift when on.
It is smart to align the truck after a torsion crank. If you crank enough, the tires will be like this: / \
na im not goin 35's without a lift, mine has 410 with a 5 speed, gona go with a 3"bl & turn the torsion bars enough to level it. when i get a chance ill send sum pix of my 04, then when i get my bl and tires ill send sum more
