03 Power Window Doesn't Work
robotsneedhugs2
Passenger window works fine. I've replaced the window motor and the new one didn't work either. Doesn't even turn.
When I press the button, there's a clicking noise under the dashboard. I took a look at the relay box (is that right?), but the clicking doesn't seem to be coming from there. It seems to be coming from the silver round thing next to it, but I'm not 100% sure.
I took the bottom relay out and the clicking stopped. I switched one of the other relays out and put it in the bottom spot, but the window still didn't work and it still clicked.
Here's some pics of the relay and the words on the front of it.
What else could the problem be? Wiring? The switch? The passenger window works fine from both the driver's side and passenger side.
Buy a test light an check for voltage. Start at the motor and work back. Also a faulty ground will make a simple problem seem elusive.
Sent from my RM-927_nam_vzw_100 using Tapatalk
I'm having the same issue with my 2003 Edge. The relay above the clicking one is hot to the touch. At first it was intermittent. Then they just quit working. I have replaced the drivers side switch. And I no longer hear the clicking under the dash. Also, both windows would roll down automatically when pushed from drivers side. I thought only the drivers side was supposed to be auto.
