bigredscowboy
Doing PA body lift. My 94 has nuts that you can easily hold while unscrewing from inside the cab. The 03 appears to be screwed directly into the bushing. The bolts will turn but they turn the bushings with them (probably rusted together). I've PB'ed them for days. What can I use to hold the bushing still while turning the top. I don't want to use vise grips on the actual rubber because I haven't found a source for aftermarket bushings (Duff, etc only go to 97).
