02 Tauras Need help
booblinker
Richmond twp, mi
Running like crap, has a cel on. I found a broken vacuum line but can't find where the hell it goes, its an 02 taurus 3.0 ohv. If any oen has oen and can tell me where it oges, or even better yet take a pic of it.
I don't know anything about Tauruses,
if I had to guess, I would say that it goes to a vacuum tap under the upper intake plenum, like a 5.0L EFI design. Can you locate the vacuum tree?
A vacuum leak would definitely cause driveability problems.
How or why it popped off? Maybe it's just broken?
Just some thoughts, could be wrong.
Pete
P0136-02 circuit malfunction
P0156-02 circuit malfunction
P1131-manufacturer control fuel air metering
P1151-manufacturer control fuel air metering
P0171-System to lean
P0147-System to lean
try to find a vaccum diagrams on the web.... or let the engine idle and spray intake cleaner around the intake. if the engine sound change your hoses probably plug at this place;) your code will probably diseapear if you find the vaccum leak.
+1, I've seen some of the most experienced techs use this method to find vacuum leaks. Use the little straw to narrow the search area, rather than spraying the whole engine at once.
