aahmes57
- Dec 27, 2010
- 2002 Ford Range
2002 Ranger Edge 4.0L 4X4 slave cylinder, rear pinion seal, clutch,pp and t/o bearing.
Anything else I should do or look at while the trans and everything are down?
Any issues that may help are also appreciated. Tips Tricks.
The trans and transfer case are left to take down.
I can also use the specs on the fluids and capacities if anyone has them.
Does the shift lever unbolt by the single nut and threaded rod through the base of the shifter or from the 4 torx?
And the CAT to the "Y" pipe connection. Dealer said the bolts are not available. They are studs pressed in. What should I use just a SS bolt not and washer?
Is there a gasket or "O" ring of anykind used at the manifold from the "y" PIPE?
Thanks for your help
