lonecountryboy
- Aug 3, 2009
- Automatic
Hey,
I have an 01 ranger that will not shift into 4wheel. I tested the motor since everybody says that is usually the culprit and it tested fine. I put battery voltage to it and moved it into 4-lo and back so I know the motor it fine. I can't find any more information on it though the chiltons manual is crap it doesn't even give you a complete wiring diagram for the truck. I need to know what fuses are in the circuit and if there are any relays involved. I checked the switch on the dash and have 5V at the switch is that right? I don't know since I can't even find a test procedure for it. The lights on the dash don't light up at all but I checked all the fuses I could find and they checked fine. Does anybody know how to check the 4WD module on this particular year or does anybody have a wiring schematic for the system? Any help would be greatly appreciated.
Thanks,
Thanks,
