geraldhuse
- Jul 8, 2011
- Automatic
I replaced cabs/ignition from a 00 3.0 flex fuel onto a 03 4.0 sohc. Everything works accept it won't start. My problem now is the newer pats module doesn't hook up to the 00 ignition module so it isn't communicating with the ecu.
The 00 3.0 has manual windows and locks
The 03 4.0 sohc has auto locks/windows
Will I have to swop out inside dash wiring harness and modules also or is there a way around it?
Also will I need to exchange out the power distribution boxes/harness only difference was the ABS everything else hooked up.
Thanks!
Thanks!
