Removing parts from my 1986 Ranger SCLB
alwaysFlOoReD
⭐Supporting Member
Airdrie, Alberta, Canada
'06, '11
3.0L
Just some pics and thoughts on taking stuff off before crushing.
A couple pics of what I'm starting with. I did lower it down to work on it. I will be pulling the motor and wiring harness to give to a friend who is putting it into an English car. The a4ld was rebuilt not long before the truck stopped running. That will go into my pinto behind the 2.8l.
Some pics of the throttle cable and cruise cable. I may keep them for some other project. Not sure yet.
And finally, the fawking fan. I'm not sure how it supposed to come off without having a running engine. If it gets in my way I'll cut it off.
Not much rust? What's wrong with it?
But there is rust in a lot of places. I hope to get the fenders and doors off at least, they can go over to my race-truck for spares. The box is pretty rotten on the other side. Cab corners are gone. Motor and trans are going to other projects. All my other rangers are getting parts pulled then crushed. I have to be off the property by years end.
And better to be gone before snow...
is this the same property that you spent all the time and effort to set up the 2 post lift on?
How many Rangers are you looking at parting out?
at least you have a few months to move things.
Yes, same property as the lift. And yes, the landlords have given me plenty of notice. Much more than is legally required.
I have the 86, a 91, a 93, and my race truck. I'll put an ad in the classifieds soon. And some other vehicles and trailers.
I have to remember that I'm not keeping the truck, it's going for scrap. Case in point, try to disconnect the fuel lines.... I spent 20 minutes looking for the tool. Spent 20 minutes trying to disconnect. Got one disconnected fairly quick but the other won't let loose. Finally it dawned on me and I used a knife to cut the lines....
So i tried to get the top 2 bolts loosened on the bell-housing. I must have lost a lot of strength over the years because they would not budge, even with another wrench as an extension. I'll see if I have a pipe that will slip over the wrench. If I have to I'll cut the one end off a cheap wrench.
I did find the tool for removing the power steering pump pulley. Even found a spare one still in packaging. That went smoothly.
Sounds like we have the same organizational skills...
View attachment 146112View attachment 146113View attachment 146114
When I go junkyarding, I intentionally carry a Sawzall and a bunch of pry bars as well as a BFH to, if nothing else, remind myself that they are parts hulks and I should just cut and smash to save time.
It only hurts to do the first dozen times. 🥲
Unless it's a BMW or GM. Cutting a BMW or GM to pieces somehow makes me feel happy.
Oh, and I found 3 other unopened fuel line disconnect tool packages as I was looking for the pulley tool...
well they do say the quickest way to find something is to start looking for something else...
AJ
AJ
Or when you are done with the job and don't need it anymore.
AJ
No, the quickest way is to buy a replacement. Buy a replacement and you usually find it as soon as you open the package or finish the job. As you can see from @alwaysFlOoReD's example above, he never found them because he obviously never opened the package or finished the job.
They imported the Taunus to Canada? Didn't know they ever came to this side of the pond. Should be a cool little ride. There were a few Saabs that got the Taunus V4 over here, and I always thought it would be cool to hotrod one of those Sonetts with the Cologne V6. Not cool enough to hunt one down, but still cool. I think the early Capris might have had the V4 too, but the versions of those I was interested in already came with the V6.
Sucks that you went through all that work and lost the place. At least it sounds like they gave you decent notice. Good luck with getting everything broken down and moved.
The one disappearing tool that bothered me the most was my engine leveler. I looked for it for two months before I broke down and bought another. My one buddy also looked all over the place.
We joked it would show up when I bought another. So I did and waited another couple weeks. Still couldn’t find the old one. Used the new one.
Like 3 months after that and I’m looking for something else and in a place both of us checked no less than a dozen times between us, there it was. It’s about infuriating.
Today I spent an hour or 2 cutting out the cats. I wanted to cut as close to the cat as I could so the next guy can easily weld a dual exhaust if he so wishes. I remember seeing a air hacksaw recently. Do you think I could find it quickly? No! I had to search high and low, but in the process found almost a dozen other air tools I had forgotten I had bought. Finally did find it tho. I modified the end guide so I would use almost the full length of the blade. That worked pretty good. The blade got dull before I finished my first cut, so I dug thru and found some old 12" hacksaw blades, cut them down into 4.5", 4", and 3.5" lengths. They fit perfectly in the air saw... But the blade were so brittle I could snap them in my hands. Disgusted, I drove down the the store and bought some new blades. That did the ticket. So I spent probably 2.5 hours on this so I could harvest and sell the cats. When I looked inside I could clearly see thru them... Shit! I remember now I gutted them when I first got the truck....
The tools I used;
5he top one I can't remember the name, maybe exhaust tube cutter. It works great!
The bottom one is the air saw. It works but seems to take forever. It's a body saw so probably not meant for thicker gauge metal. But it did the job much easier than a regular hacksaw.
I was surprised how thick the metal is on the inlet to the cat, looked like 120".
And the view thru....
