Brake booster leaking from valve when engine is off
gungfudan
⭐Supporting Member
Mississippi
3.0L
N/A
N/A
So this is probably a simple fix when I turn the engine off there is hissing coming from the brake booster, but it’s right at the valve. Should I replace both the grommet and the valve? Also, do I need to check anything else? That’s the only place it seems like it is leaking.
Sounds like a simple way to start. Try the grommet.
It was the grommet, but it was hard to find. It seems like the only place I could find it is Advance Auto Parts. It comes in a kit with two grommets and a check valve. I went to one Advance Auto Parts and someone stole the gasket out of the package I needed.
