Transmission, Tcase, and Power Steering Fluid?
It actually wasn’t an ai chat bot on the other end, I was transferred from that to a person, the person just spoke like an ai chat bot and I called him out on it too later on😂
Your screenshots won't bother the little AI chatbot a bit.
I would rather have aftermarket dex/merc or whatever than the Ford stuff that may or may not kill the trans.
The controversy over the V is why I went Penzoil Syncromesh and just bypassed all the drama.
Hmmmm now I’m scared to use the Mercon V I just bought😭 I know not to put the V in your tcase but I would imagine it’s fine for the trans
I know some internals of the M5OD changed in later years (when?), and that at some point ford did recommend Mercon V. Although there are reports of people using it and having more noise or harder shifting. (What models were they used in? Was there already a problem the V just made more noticeable?) Lots of variable there.
I just stick with the cheap aftermarket Dex/Merc, though I suspect 85_Ranger4x4 has the best solution with the Synchromesh.
