I got a cracked windshield. I was driving on Hwy 50 and noticed something sparkly bounce across the back of a flatbed trailer. It ended up hitting my windshield causing a four inch long shatter where it impacted the windshield. The force of the impact also made a long clean crack from top to bottom about 24 inches from where the impact occurred. I noticed something else fall off the flatbed a few minutes later.
Just finished investigating a clunk in the rear end. Passenger rear axle seal is starting to weep and might have excessive endplay. All my indicators are at work but it's probably between .020" too .040". It's the smaller rear end, not 8.8. Too cold to check driver side but I will tomorrow and bring an indicator home.
*Edit, the picture is after I brake cleaned and sprayed some penetrant by the seal only. That's why it looks so wet. But there was a trail of fluid coming from the bottom of the seal when I first pull the drum off
The 7.5" is still a C-Clip axle. Roughly 1/8" (give or take) end play is normal.
Thanks. At most it's probably .050" so I'm good. I just got back from O'Reilly's with 2 axle seals and some rtv. Only rust on my truck is the corners of the bed from leaves under the plastic liner. But my axle end sure did get pretty flaky.
Yeah, I’m with PJ, I replace the bearings when the seals go. I usually examine the axle shafts while it’s apart and sometimes use the repair bearing and seal. Also, the Ranger 7.5” rear and 8.8” rear both use the same bearings and seals at the ends of the axle tubes. Some parts stores try to sell F-150 bearings and seals for the 8.8” in the Ranger.
Oh wise ones, riddle me this one, an oddball….
When the temperature goes down below about 30° at night, and I drive out in the Missing Linc (87 2.9 stick), I have no brake lights. Once the heater is blowing for about 10-15 minutes and the inside warms up a little bit, then the brake lights work like they always have. I’m not sure if it’s warming under the dash by the switch that’s the issue, or something under the hood when the engine warms up.
Let me digress and say that I put fender mounted indicators wired to the brake lights on the front of my hood. I always put a fuse between the truck and a trailer, and I wire those indicators from the trailer brake light circuit. It’s how I know if the trailer lights are working. But you can also see how the brake lights are working in general.
I’m planning on replacing the pedal switch, but I’m wondering if anybody else has had this problem. I’ve never seen something like this before, the switch always seems to work or not work, but not be stubborn when it’s cold.
Any and all comments are welcome
Are you sure that none of the brake lights work? You could remove the trailer light fuse. If the truck brake lights work, then you know the problem is in the trailer circuit. If the truck lights don't work, you know the trailer circuit us not the problem. I’d start with that test to cut the problem in jalf.
maybe the switch is just sticky since its cold? they are spring loaded right? maybe the spring metal is not working hte cold so well
Makes sense, but some more info. I’m pretty sure it’s something between the brake pedal and the master cylinder, and I think the only thing electric in between is that switch on the brake pedal.
When I start out cold, if I play with the brake pedal or if I push it down hard, I can get the lights to come on. But just driving normally, they don’t light up with a slight pressure like usual, only when I fiddle with them.
It’s probably the switch, I’ll replace it
Radio update….
I picked up a radio, almost exactly the same as the one that was in the dash, off marketplace for $30. I also put a green LED in the HVAC controls.
And the cassette works. All is right with the world.
Choptop got new front sway bar bushings on the frame side of things. The old ones were egged out and cracked. Really would like to throw new shocks on the front and see how it does but I’m still waiting on money to get shocks.
I can fix it, right? Right?
I really don't like this mod...
that being said, the frame is probably not bent, but you will need at least a hood, fender, grille, front clip that holds the grille and headlights, light/ turn signal, bumper, header panel and whatever is broke behind all that. don't see any coolant on the ground, so hoping that the radiator and condenser survived. if you can source all of that fairly inexpensively and have the time to tear into it, probably worth fixing
