Ammeters suck!
VirtualToaster
Forum Member
Wisconsin
28"
That's why I destroyed my ammeter gauge and soldered in a volt meter into it. All in all very easy, I just have to remember to ground the yellow/light green at the voltage regulator. Why they don't make a drop in kit, I'll never know, but boy this would be easy to manufacture.
  • Ammeters suck!
  • Ammeters suck!
  • Ammeters suck!
  • Ammeters suck!
  • Ammeters suck!
I'm curious now, what exactly was the issue? Not trying to question your resolve, I'm only willing to hear what happened knowing it's a possibility I may have to do something about it to someday.
Problem: ammeter never worked
Plan: replace it with a voltmeter
Solution: voltmeter in place
Cool idea, and nice work.
My charging system is like perfect, ammeter was always centered in the middle, it never under or over charged just perfect equilibrium!
Likewise when I swapped to a tach cluster the charging light never comes on either!
Your little mod would be really nice in the charging light window below the oil pressure light...
Ammeters suck!IMG_6733_zpse1i3fxvb
I think this would be well worth posting a tech writeup on. Please post it here:
With this format:
Much like everybody who does anything, I'm unable to get back to my bronco ii and finish up the voltmeter at this time. It is in place and connected to the cluster but I haven't been able to verify that the voltmeter works. I mean all in all it was fairly easy, I think 86-88 has a warning light that is wired similarly to the ammeter.
