- Apr 5, 2011
Here's the low down:
1993 XLT w/2009 Ford rebuilt 3.0L V6 short block.
5 speed OD manual tranny (original)
K&N cold air intake.
Underdog pulleys.
Electric fan.
MSD coil, new plugs, wires, cap and rotor.
You would think this motor would have some power, wrong. It runs fine as long as I am on a flat surface or going downhill. Once I start uphill, it's like there is no torque at all. Even when I mash the accelerator to the floor there's no power, just the sound of more gas burning.
I'm not sure if it is a compression issue, vacuum issue, PCM issue or what. I've thought about adding a Jet module to see if that would help, but wanted to check with you guys before I did to see if maybe someone else experienced this same problem and had some advice.
Let the threads begin.
Dave93XLT
Underdog pulleys.
Electric fan.
Dave93XLT
