Blinker fluid??
While you are doing the muffler bearings, don't forget to check the muffler belt while your'e at it.
if your muffler was manufactured after july '01 it has chain and sprockets in it no belt they upgraded them ..
Don't forget to make routine checks on the windshield fuses.
Don't forget the three foot metre stick, the left handed metric screwdriver, and the 2x4 stretcher.
But if its anything like the 4.0 SOHC, you have to watch out for the death rattle from the chains! It may be an interference muffler.
Never overlook the the gas cap snap ring, or the air filter inside the air bags.
call the parts store and ask about 1983 corvette parts:icon_confused:
44 Corvettes were manufactured with a 1983 VIN numbers but none were released to the public as official production vehicles. These 1983 Corvettes were prototypes, alpha test vehicles, and beta test vehicles used to sort out production details while others were assigned to engineering evaluation and crash testing. A few were part of a press introduction at Riverside Raceway in California, December 1982. The 1983 Corvette resembled the newly redesigned 1984 model (4th generation Corvette). All were destroyed except one, VIN# 1G1AY0783D5100023 (white with medium blue interior), L83 350ci, 250HP V8, 4-speed Automatic transmission and was retired to the National Corvette Museum in Bowling Green, Kentucky. It is owned by GM. It was saved from destruction by a few forward looking individuals who recognized the need to retain one 1983 Corvette for posterity.
Read more: http://wiki.answers.com/Q/Is_there_a_1983_corvette#ixzz1HgHKuy2x
Sneaky :icon_thumby:
I like to go in and ask for parts for an '82 Delorean, list off stuff like fan belt, plugs, etc, and a flux capacitor, and then wait and see how long it takes for them to get it. :D
Damn, I had to go over that like 5 times, apparently its time for bed, only been up since 6....
lol @ new members and necro threading!
anyways, now that the thread is alive again... the trucks we work on do have themuffler bearings, but the bike i have (85 yamaha virago) has the elusive muffler smoke, if you remove the baffles from the mufflers, there's a good chance some will leak out, and once it's out, it's almost impossible to recharge...
atleast with the muffler bearings, you can get the tool to replace it...
crescent now makes a metric crescent wrench... i'll find a pic...
edit:
FOUND IT!
I cant believe you all. none of you remembered the most important aspect of vehicle maintenance. You have to flush your engine with saltwater every oil change, then run it for about 10 minutes before putting new oil in so its nice and dry!!!!
While your under there check out your shock absorber fluid level, and coat the brake rotors with grease so they don't wear out to quickly.
Fallopian tube bender. I got a ton of newbs with that one.
