need a bigger alternator on my 84. ideas?
84stealthranger
murphy north carolina
now that i have my winch and lights hooked up i think im in need of a much bigger alternator in place of my stock 60 amp junker lol. does any one know of a alternator that will work with the same connects on the back? im not to worryed about mounting it. and will a 1000 cranking amp battery kill my starter or would it be ok?
I've heard of getting high amp alternators from the old 6.9L non turbo diesel engines and as for 1000 cranking amp battery, I havent toasted a starter yet.
so a 1000 cranking amp battery would be good for a winch and lots of lights? or would a deep cycle work better?
I would personally look into the deep cycle Optima batteries but I run a everstart battery from wal-mart and it hasnt let me set yet. They're about $120 but you can get a new one anytime it fails for 3 years ( 3 yr warranty. I ALWAYS get a new battery when the 2 1/2 year mark comes around) I havent paid for a battery in over 8 years....lol
If you upgrade the alternator and battery going with larger battery wires are recommended. Also switching the added components winch/lights with a relay so they run direct from the battery but use the ignition switch accessory circuit to energize the relay takes alot of the load off the stock wiring. You can get custom cables made using marine type battery clamps for good solid connections and make it easy to add components.
i was looking in to a deep cycle optima but they cost so much and im not sure if thats what i need. ever start would be good i guess. our walmart is open 24/7 i might just go with something from there and if it tears up on me ill just go get another one lol
right now i have the winch hooked to the pos and neg on the battery. and for my lights i have a 40 amp relay. im kinda of confused about what ur talking about with the ing switch circuit? i have all new wiring for my lights.
I wouldnt recommend deep cycle you want the cranking amps.
for a winch what would be the best? the cranking amps or deep cycle. when its under a hard load it really draws the power down they volt gauge reads 10 im thinking i need a much bigger alternator. and for wire for my light i used 12 gauge stranded house wire. i guess its the stuff used to wire up commerical buildings and trailers.
These guys know alot about upgrading wires I bought some for my jeep because I wasnt happy with aftermarket cables available.
http://www.kelleyswip.com/electric.html
They can make custom cables to spec that are rock solid at a pretty good price but you can get alot of good info your looking for here.
wouldnt that be over kill for my lights lol thats about how big the wires for my winch are. i have a optima red top i can put in do u think that would be big enuf?
you might want to consider a dual battery set up. one for the winch and the other for everything else. a good deep cycle or marine/starting battery for the winch and a regular car/truck battery for lights, starting, etc. easy setting up dual batteries with an isolator so they will both charge from your alternator. that will also give you a back up battery in case one goes bad on you when you're on the trail.
just a thought.
Your wires for the winch and lights are probably fine I`m talking if you upgrade the alternator and battery. Depending how many amps you want to size the battery to the alternator and if you go above 100 amps you need to consider lower resistance battery cables #1 or bigger if your going 150 amp alternator but #4 would probably work ok for 100 amp. No way to fix it out in the woods unless you get creative with jumper cables. Sorry about the link there used to be more info there someone here should know the best way to upgrade your alternator and battery or do a search. It depends alot on how many amps your winch/lights pull you can wear out the charging system real quick even if your wires are big enough, adding a ground from the batt neg to the alternator housing is pretty much mandatory to reduce resistance.
