My truck's growing up again...
scotts90ranger
25+ Year Member
Dayton
OR - USA
Drive
when I got it:
4 years ago:
Right now:
The day the teardown started:
In process:
Spare parts:
The front lift is done shy of bleeding the brakes and getting alignment bushings, the rear needs the spring perches welded on and me to order the right U bolts and put shock mounts on.
thats a clean ranger! reminds me of mine! :D
This summer were gunna have to have a TRS wheeling meet
yep... definitely need to get a wheeling trip going this year.
well, you aren't seeing the drivers side, and from the pics I posted you can't see the dents in the passenger side...
Lift Done!
lil bit of tire overhang...
After some fender trimming:
Drivers side brake line mod, had to change from metric to standard nuts, and run a 3/8-24 die down the tee
Front suspension
Rear suspension
I know the alignment is off, that's what the camber bushings sitting in the kitchen are for...
look's like you have the same issue i had with camber
the daylight pictures make it look worse than it is since I just rounded the corner into the driveway sitting there, it's toed out about 1/8" at the wheels which probably isn't helping, still need to center the steering wheel a little too. The camber on the passenger side hasn't been touched, drivers side was adjusted some.
well, it's not as straight anymore...
it def looks like a dedicated trail rig now!
i like the lift n all, looks good... what ya gonna do with the damage?
you oil leaks make me feel better about mine..lol
