- May 10, 2010
- haida gwaii
something else to keep in mind regarding the use of a trac bar on the ford solid axle 3/4-1ton trucks.the spring/shackle setup was designed to be used with the ttb d44/50 front end.the shackles had very narrow tops to allow easy side movenent for the ttb to work.when a solid axle was installed,the same shackles were used,and so a method of locating the axle against side loads was needed.
note that while a trac bar was used,there was no attempt to properly phase it with the steering linkage on the crossover.
