skyjacker leaf springs SKYFR34S
canyoncritter
San Diego
ok, I'm may be swaping out the skyjacker springs with a diffrent set. So Im going to sale the skyjackers to recoop someof my money.and hopefully make someone elses day.
heres the question I got, they will fit on a 98 ranger and newer correct?
Im 99.9% sure, but I dont want to screw someone ethier...
I'm 99.99% sure the only things changed from atleast 83+ was spring rates and leaf packs. but should still be 2 1/2 wide by however long
they will fit no problem...i am 100% sure....i have put a set on a '03 Ranger before...
56.5 I belive. They are still on my truck. hopefully be off in the next few days. waiting on thier replacemnts. And Ill measure them.
I have a handful other people in line at the time.but things happen so ...
are they lifted springs? How much lift? what are you asking for them??
I just searched the parts number, and they are the springs that i want so now to my third question.....How much?
they are 4" of lift WITH the stock 2" lift block and they are 2" of lift with NO lift block...
how soft are they compared to stock springs or how hard are they compared to superlift springs? How do these rank for flex in em?
All 4wd Rangers have a 2" block under the leaf springs to level the rear......
level the rear? every stock ranger Ive seen sits stink bug,except for the special suspension packages
that is to compinsate for putting weight in the rear of the truck.....most Rangers that are noticeable raked like that are the 4wd regular cabs.....
just take it this way, if all 4wd Rangers didn't have the lift blocks in the rear, the rear would be 2-2.5" lower than the front.......
lift block =2 or 2.5 inches. most all leveling kits are 2inches....so is it safe to say most rangers sit stink bug aprx 2inches.?(or is skyjacker and superlift being misleading?)
so lets say instead of lifting the front 2inchs to level out the truck, we took out those 2inch block's. The rear end is going to be setting 2-2.5 inches lower than the front? without a load in the bed or a tralior hooked up to it?
