fuel problem, started with the fuel pump
STX1992
20+ Year Member
so I get up sat mornin an the temps are in the low 20's, truck want start, cant hear the pump turnin on. So later in the day I replace the pump, starts up an idles fine, runs fine till you pull up to a stop sign or turn in an try to accelerate. Only does it sometimes an sometimes it want do it at all. When it stall most of the time it'll start rught up then sometimes its gota set a few before it will fire up. Any ideas? its my DD so I gota make sure its reliable. Thanks For The Help
