- Oct 19, 2007
- Age
- 37
- Lowell, IN
I change mine every 10k miles with a filter and a quart at 5k. I use Royal Purple with a K&N filter though.
Coolant, like gear lube for the axles and transfer case I think is one of those fluids that really dont need to be changed unless you find something wrong with it. Bascially if it looks good, then its okay no matter how long its been in.....as stupid as it sounds.
You want to know what my t-case fluid looked like after 100K? Black with a slight redish/brown hue.
How about my diff fluids? Metallic dark brown......
remember, the diffs are supposed to be lubricated for life according to ford...![]()
Ford put a special synthetic in those......'lifetime diffs'. Want to know what those axles and axle bearings look like in most of those around the 100K mark??? Most start making noise around then.......
Most manufactures design a vehicle to give 10 years of service MAX. But we are making them last much longer. The engines are lasting much longer......
And guess what?! Proper maintenance and frequent fluid changes help a vehicle last that much longer.....![]()
but remember, most of us own trucks that werent designed to make it past 100k miles lol, thats why the odometers only had 6 digits(5 and the 1/10ths)
The average lifespan of a vehicle is 7 years. A lot die before that, and those that last longer make it stretch to that mark.
Not because of mechanical issues, but because they were wrecked/destroyed in a storm... that kind of thing is what takes most vehicles off the road.
I really think that's a stretch.....I would think that most middle class in America....and that's about all of America..... own vehicles that are 7 years of age or older. Just saying.
change all your oils on some kind of schedule or you'll end up with this stuff.
Most people usually don't check the oil very often, and many newer cars still burn oil. My fiance's 2002 Beetle burns enough oil that I have to put a quart in it between oil changes that are roughly 3k apart. Ive read this is actually normal for this car, yet freaking ridiculous. I would be pissed if my 8 year car burned that much oil.
