- Oct 21, 2008
A nice alternative to the rinky-dink safety I also found on there is to click the bolt over a little bit from straight up (there is a detent) and pull the trigger (pointed in a safe direction of course) and it will uncock the bolt as it spins down. No way the gun can go off then unless you pull out on the bolt knob (easier than running the safety) or swing the bolt up and back down to recock it.
I would advise against that. When the Mosin Nagant is "decocked" the firing pin is exposed, so the firing pin would be resting on the primer. One good bump and boom. See for yourself, pull the bolt out of your mosin, and turn the knob 90* counter clockwise(like you would when you disassemble the bolt) that is how it sits when it is "decocked".
As for the safety, crude? Yes. Rinky-dink? No. It is a very simple, strong, and affective design. When engaged it locks the firing pin back and essential locks up the entire action.
If you dont like the Mosin safety, I believe Timney makes a drop in trigger with a Remington style safety.
http://timneytriggers.com/sunshop/index.php?l=product_detail&p=50
-Jester
