ring and pinion intsall instructions
cashmoney37
South bend, Indiana
I am looking to do a gear swap on my ranger from 4.10's to 4.56's. and i have been looking for a installation guid or post somthing that says how or steps to installing them in a 7.5 axel. i cant find nothing. i would appreciat n e help.
Aside from the specs, i.e backlash, pinion bearing preload, etc. it shouldn't be any different than setting up an 8.8. If you look in the tech library, there are some good 8.8 guides.
I looked it up and the 7.5 and 8.8 have identical specs when it comes to gear setup.
Backlash: 11-16 (thousandths of an inch)
Pinion bearing preload: 14-19 ft. lbs.
Cap bolts: 60 ft. lbs.
Ring gear bolts: 60 ft. lbs.
Its actually
8-15 thou backlash
70-85 for both the cap and ring bolts
8-14 INCH-lbs pinion bearing preload for used bearings, 16-28 for new bearings
(this for both 7.5 & 8.8")
Some links in this post are about how to install gears ;)
http://www.therangerstation.com/forums/showthread.php?t=10228
Hmmm....I got my specs from DTS.
http://www.drivetrainspecialists.com/setupspec.html
But I think those might be wrong. The numbers you listed seem familiar from when Todd and I set up my gears.
