Ok, I'm going to try to lay this issue to rest.
I gave in and tried using Acetone once. I had a good baseline of fuel economy set up - I had calculated it over several tanks of gas and the average was around 19 mpg, plus or minus about .65 mpg. Tried the Acetone for several tankfuls with the same driving habits and calculated my fuel economy. There was absolutely NO noticeable change. None. Nada. No increase or decrease (except to my wallet for buying the acetone). Truck didn't run any better on it or any worse either. I've gotten more gains out of changing spark plugs and running a can of Seafoam through a motor than with acetone.
You want to know the best way to increase your fuel economy? (aside from buying a more fuel efficient vehicle that is). Run pure gasoline, not this crap that they push on us anymore with "up to 10% ethanol" or "Winter blended gas" or the new one "up to 15% ethanol." When I could still get pure gas locally for my Ranger, I was able to get 21-23 mpg around town with a tonneau cover and 300# in the bed. With 100# in the bed and the bed cover I was able to get up to 31 mpg highway. With this ethanol crap, my flex-fuel rated Ranger went from 21-23 around town to 17 mpg. And with ethanol in the winter blend it went down to 15 mpg.
My F-150 is no better. I was getting 13 mpg with the ethanol blend. Now with winter gas I'm getting 11 mpg. I'd bet that with pure gasoline I'd be up closer to 17 mpg around town.
The F-350 here with a 460 gets 8 mpg. Not sure if it still applies, but they used to only put the ethanol in 87 octane. Jumping up to 89 octane gas we gained about 2 mpg around town.
A fantastic post, to be sure. But this topic will never be put to rest...like that fugly ranger with the mustang front end. It's just going to keep getting posted every other month no matter what we do.
