- Jun 15, 2010
- USA/Minnesota
Champion Labs makes the K&N filter. It is almost exactly the same as the Mobil 1 filter since they are both based on the same design.
I have something to add.
All the filter area and construction stuff is great, but what about it's actual filtering ability?
Is there any one you know of that would know how many microns the media filters down to? Or the pressure it takes to pop open the bypass valve? (could probably test that one)
Maybe take a square section of filter media and see how long it takes of medicine cup of a generic 5W30 engine oil to seep through it, the longer it takes the smaller the holes.
That'd tell a much more complete picture.
You are correct.so from my understating... the purolator gold and the motor craft are the better of the filters.. they filter out More media have metal end caps, media is thicker. correct?
RECOMMENDATION:
AMSOIL recommends changing the EaO13 Oil Filter according
to OEM-recommended intervals in the following
applications:
• 2001-2010 Honda
• 2002-2010 Acura
• 1992-2006 Chrysler imports
• 1993-1997 Ford Probe
• 1996-2010 Nissan/Infiniti
• 1971-2000 Mazda
• 1999-2000 Mercury Villager
• 1990-2010 Mitsubishi
• 2004-2007 Saturn
Customers using an EaO13 Oil Filter beyond the OEM recommended
interval in any of the listed applications are
advised to change the filter at the earliest opportunity. If
the oil light is triggered, change the filter immediately to
avoid damage.
ISSUES:
According to the July 2009 report from
ConsumerReports.org, engines from four different
automobile manufacturers are candidates for possible
sludge problems. To satisfy customers,
Audi/Volkswagen, Lexus/Toyota and Saab have
all extended their warranties to eight-years/
unlimited mileage. Chrysler/Dodge is the only
manufacturer without an extended warranty program
and handles claims on a case-by-case basis.
Provisions of the extended engine warranty
coverage include changing the oil within the
OEM-recommended interval and maintaining
documentation for proof.
Follow regular OEM-recommended drain
intervals with the appropriate AMSOIL Synthetic
Motor Oil for cars prone to sludge. The AMSOIL
XL series oils may be a more cost effective option
depending on personal preference.
OBJECTIVE:
Inform customers of an issue regarding the oil sensor tripping
in the following applications:
• All Toyota/Lexus Vehicles
• Pontiac Vibe Featuring the 1.8L Toyota-Built Engine.
TECHNICAL DISCUSSION:
To protect the engine, the OEM has engineered the oil
pressure sensor to trigger the oil light when there is insuffi
cient oil pressure to maintain an adequate level of protection.
Each filter is equipped with a by-pass valve, so when
the filter is at or close to capacity, the engine is continually
supplied with adequate lubrication oil, although unfiltered.
However, if the filter reaches maximum capacity, the level
of restriction can become significant enough to trigger the
oil pressure warning light. In extreme situations, oil starvation
could occur.
Premature oil filter capacity can be attributed to a number
of factors such as poor air filtration, a leaking air intake
system or excessive contaminants being produced in the
combustion process. As discussed in the AMSOIL Technical
Service Bulletin Using AMSOIL in Engines with Possible
Sludge Issues,1 certain engines are prone to accumulate
sludge, including some engines from Toyota/Lexus.
RECOMMENDATION:
When used in conjunction with any Toyota/Lexus application,
or with the Pontiac Vibe featuring the 1.8L engine built
by Toyota, AMSOIL recommends changing EaO09 and
EaO10 Filters per the OEM-recommended change interval.
AMSOIL no longer recommends the EaO57 Oil Filter
for Toyota/Lexus applications, however, it is still recommended
for other applicable vehicle makes and off-road
equipment. Customers operating any of the above listed
applications with an EaO09, EaO10 or EaO57 Filter in
service beyond the OEM-recommended interval should
change the oil filter at the earliest opportunity. If the oil
light is triggered the filter should be changed immediately
to avoid damage. AMSOIL also offers WIX Filters as an alternative
to the Ea Filtration line and recommends the WIX
51348 Oil Filter for Toyota/Lexus applications that previously
called for an EaO57 Filter. If a WIX Oil Filter is used,
AMSOIL recommends changing it at OEM-recommended
intervals.
