Ask and you shall receive... let the carpet bombing commense.
This is what I have gleaned from this site in my own swap thread, the pics were posted in my thread or I dug up elsewhere on this forum, plus I have a couple of my own in there.
Hedman 88400's, truck unknown:
In my truck, of note is that these headers are intended for 1960's cars with a front mounted dipstick. For best results you have to use a steel dipstick tube because it is tight between the header and the block. Passenger side outlet pretty much requires a bodylift (I have 3") or extensive firewall beating.
Hedman 88400 on a 351W thanks to
@Grunizzle
I know the 351W is wider and taller. Anyone know how much taller it is at the exhaust? Any deeper between the oil pan and the engine mounts? The exhaust is tight to the floor now on the PS side and the oil pan is tight to the crossmember... I don't have a ton of wiggle room there.
Any 351W header pics (especially Hedman 88400's) would be much appreciated too.
Shelby Tri-Y's, '89 2wd with a 157t C4, Baddad's.
Why Tri-Y's won't work with a 4x4, my truck with stock suspension. The 2.8 and A4LD are still in place as well.
Why they have a problem with the 164t bellhousing. That is a 164t seperator plate. On my engine.
Patriot H8430's, in Wade's truck. It looks like he is using the V6 mounts with a plate vs the fox convert/sn95 mounts that Totalled used with the 88400's, that might effect the height of the engine relative to the frame.
EDIT 2/9/11
Since people are always asking about SN-95 Mustang headers, and some say they do work while most say they don't I decided to check into it.
(Heddman 88400 above)
The engine is sitting on the engine mount studs so it will sit lower (probably an inch or two) in real life.
The driver side looked like it would fit (and is supposed to) but I wasn't gung-ho enough to try to snake it up from underneith by myself.
