Gasket between trans and t-case
Seahawk
I'm about to put my friend's 88 ranger back together after a clutch and slave cylinder replacement. The transmission and t-case were litterally covered in oily dirt so we pressure washed them both.
However, I want to replace the old paper gasket that is between the transmission and transfer case. A few other threads said there is no gasket, just RTV, but I know for sure there is a gasket there because I saw it.
Anybody know what this is called? I can't find it on either of the exploded diagrams for the transmission or transfer case.
http://www.therangerstation.com/tech_library/diagrams/electric1350.GIF
http://www.therangerstation.com/tech_library/pdf_documents/Mitsubishi5speed.pdf
I'm not talking about the transfer case input shaft seal either, it's just a paper gasket that goes between the two units.
Thanks.
Thanks.
the ford dealer sells them for around $10, but i always just use silicone rtv
No Fluid even crosses through that section.
Depends what tranny.
It's an 88 so it could be a FM146 which is wet in the extension housing. The M5OD is dry in the extension housing so I don't seal it. I believe the A4LD is also wet in the extension housing.
no i know the newer a4ld is dry, at least everyone that i pulled, but not sure bout the 80's versions
