country0001's Blue B2 build
I want a 2wd Bronco so bad.. and I want to split the rear hatch as well...
Oh side note: You NEED BITCHIN TIRES!!!
I'll drop you a PM if I find something tire wise
FrankBoss
Just need 2 more mud tires, 30 x 9.5 15
Need a tailgate and hardware for my hatch idea.
MOOHAHAHA. I found one on here somewhat locally. He's having it delivered on Sunday.
Got hatch mounted today. Shimmed it a little bit to make it close better. Freakin love it.
Started realizing that I'm building my perfect B2. But its spanning over the entire run of the B2 production.
My truck is a 90 w a 94 ranger 4.0. It has the 90 A4LD w/ a 88 manual tcase( next weekend) I have 88 doors w manual windows, 84 rear hatch w opening window, 89 front clip and about 6 cans of rattle can flat black
I have been trying to figure out what you mean by 2 piece hatch. I have an 84 with opening window.
My original idea was to cut my hatch in half and put a tailgate in also. That way i could have access to the back without opening the talgate and having everything spill out
dude swap that to 5 spd it will be way bettter than the A4LD, in my opinion no ranger or b2 is right without a manual trans.
Well, I'm fine with this one being an auto, My other B2 has the M5OD. It'll be next on my project list. I wanna put a d35 in this one first, and I'll have to find a donor for my other B2. This one will be my dd, the next one will be my extreme. I'm thinkin sas and full width. I think I'll stay w the 4.0 tho.
New hatch with widow open.
Went ahead and put my mud tires on cause they're bigger.
Gonna swap t case's this weekend. Should have done it when I had the tranny out.
Any tips on doing this while in truck?
BTW, had to do my 1000th post in my own build. Yay
Brings to mind that old Johnny Cash song "One Piece at a Time" LOL . . . will get a closer look tomorrow.
Too bad your not closer, ive got a set of 4 BFG MTs 30x9.50x15 that id sell for $100, but the shipping would be 3 times that probably.
I appreciate the thought, that's normally the way things go on here. Someone on the other side of the country has what you need.
I've got some new ideas spinnin in my head. Probably in the spring, I'm going to swap in my D35 from my other B2. Gonna build my own extended radius arms and new tranny crossmember. The duff kit is 600 bucks, but it doesn't look that hard to do. I have more time than money.:icon_welder:
Still need to swap my t case. Just trying to find the downtime.
Found a D44 SA for my other B2.
There is a guy over on broncoii.org that did a 2 piece hatch. Cut the hatch in half then used a Ranger tailgate. Its pretty badass, but then so is the opening window.
Thats what i wanted to do. Then I found my hatch. Might still do it.
