- Jul 5, 2008
- Age
- 40
- Orange County, CA
- 1994chassis-200
I am tired of burning through bearins on my d35 hub. ive been told in the past that the ball joint taper in the bottom of the beam can be re-drilled to match the BJ on the dana 44 knuckle from the bronco beams. does anyone know if this is true, and if so, how to figure out the taper?!?!
also, if anyone has 2 sets of dana 44 knuckles im looking to buy. need the bolt on snout and calipers, but nothign else. i dont use use 4wd.
REPEAT! i do NOT use 4wd. i just want a stronger wheel system holding my wheel on at 75mph in the whoops.
