installing a steering stabilizer.
xkotyx
Waynesboro, VA
mine didnt come with instructions. rather than trial and error and trying to figure it out for an hour before i actually figure how to do it, it would just be much easier and faster if anybody would know where i could find some online instructions. or if some one could tell me the mounting points on the truck for it...
any help is appreciated.
I just got this b-II, didn't install anything myself. In any case, here's a pic of the stabilizer that came with it;
The one side bolts to the beam and that's kind of hidden in the pic. You can just see the aluminum L shaped bracket behind the pitman arm. The other side is supposed to be connected to the drag link with another L shaped bracket, you can see where the paint is rubbed off, close to the passenger tire.
Hope I helped,
Richard
Hope I helped,
Richard
great help!:icon_thumby: any chance you could get another pic from a better angle? if not i understand. i should be able to fill in the blanks from there.
I'll try to remember next time I'm out to the shop.
Richard
Hope I helped,
Richard
Where did you find that stabilizer at
I didn't. It was already installed when I got that b2.
If you follow the guide in the tech section there is no need for one.
