- Dec 8, 2009
- Evansville , IN.
Should the axle pivot bolts be the same distance from the ground ? I bought my lift used and have the bolts in the top holes of the brackets but the passenger bracket bolt is 1" higher than the drivers side. The passenger is 1" higher than hub center line and drivers side is even with hub center line. Doesn't seem right to me
