lil_Blue_Ford
Cut & Weld
⭐Supporting Member
💻 TRS Socials
TRS 25th Anniversary
- Aug 6, 2007
- Butler
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Total Drop
- 4”
Just a quick update...
Yesterday I pulled the 2.9 out and cleaned the whole engine bay out. Today I set the 4.0 in and bolted everything down tight. Im kinda sketchin out about the motor mounts. From what i read I thought you had to drill out something to fit it in, but mine just sat right down with no modifications. Is this right???
I have to cut a new hole for the shift knob to come through. Its about an inch forward from the other one. The Air Force Auto hobby shop is closed tomorrow so Im goin to run down to the salvage yard and get some odds and ends to finish wiring up.
The new transfer case is a electronic shift, so I have to figure a way out to get it working right.
I might just go down to a junk yard and find a 94 exploder to literally take every wire and switch out and just replace everything so I dont have to worry about screwin up.
I had heard that too about the motor mounts, but my 4.0 dropped right down on 'em too. Well, after a bit of shoving and prying it dropped right down. (Used a backhoe as a cherry-picker for the motor).
If you had a manual t-case before, you can put it on an use it instead of trying to wire up the auto t-case, unless you want the auto t-case. To wire up the auto t-case you would need the wiring harness for it, the computer for it, and quite likely the switches for it.
