4.10 would help some to get back near what the stock final drive ratio was, if it sees more trail than road maybe go 4.56 to move a little more in the low end area. Also, if your road driving consists of mostly under 55 MPH i would go 4.56
4.10s or lower if you are in town a lot. On the highway I might have said something a bit higher, but 4.10s at least.
4.10 gears should preserve your stock drive ratio pretty closely. 4.56's will drop it a bit and make starting easier. 5.13 gears might not be a bad idea if you stay in town and never go above 55 MPH. Those will kill you if you ever get on the highway though.
Go look at the tire and gear chart. That should give you some idea of what you will be looking at.
thanks ill look at the chart. i was htinking 4.10s too but theyre expensive as hell for the d35, more expensive than 4.56s or other gears. so i might be sticking with my 3.73s
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
