gear ratio questions
Boggin
1. what would be the best gear ratio for fuel economy with a 3.0 automatic and 33x12.5s? currently have 3.73s
2. is an installation kit necessary?
thanks
Fuel economy with 33's and a 3.0L does not add up. You will have a tough time at the pumps no matter what gear.
i know im just looking for the best i can get
depent all what you do with your truck. the highway or driving with a load-- for me wanted to work in 4.56
town driving and trail riding
4.10 would help some to get back near what the stock final drive ratio was, if it sees more trail than road maybe go 4.56 to move a little more in the low end area. Also, if your road driving consists of mostly under 55 MPH i would go 4.56
4.10s or lower if you are in town a lot. On the highway I might have said something a bit higher, but 4.10s at least.
4.10 gears should preserve your stock drive ratio pretty closely. 4.56's will drop it a bit and make starting easier. 5.13 gears might not be a bad idea if you stay in town and never go above 55 MPH. Those will kill you if you ever get on the highway though.
Go look at the tire and gear chart. That should give you some idea of what you will be looking at.
thanks ill look at the chart. i was htinking 4.10s too but theyre expensive as hell for the d35, more expensive than 4.56s or other gears. so i might be sticking with my 3.73s
33s and 3.73s will kill you dude. On the highway it would be BA. In town it will suck.
ok. i might just leave the 33s on the 79 then and put the bald 31s on the ranger lol
I recommend 4.10's on 3.0 2wd Rangers running smaller tires.
So 4.10's certainly aren't going to hurt...
AD
AD
Isn't recommending 4.10's kind of a long-standing past time here on TRS?
Every new thread about getting more power immediately gets replied to with "4.10s and if that isn't good enough put a 5.0 in."
3.73 to 4.10 isn't going to be that noticeable. 4.56 is what you are looking for with the 3.0 and 33's.
The 3.0L likes the revvs.
4.56 at least. That will put you at least back to stock final drive ratio. With a 3.0, 33's and 4.56's even my speedo was correct.
