If it dont work and you have no plans on making it work yea pull it and plug the vacuum lines. The first thing I did was remove anything not being used wires, vacuum lines, sensors, solenoids. I hate loose wires the only wires I needed to cut were at the 8 wire connector by the coil. I cut the computer power wire but left the power to the coil and cut the coil neg wire and spliced the green from the module into it. With the 83-84 power to the module is just plugging it in the colors are backwards but is correct. 85 takes two cuts and splices to power the module correct but real easy once you understand it.
