- Jun 12, 2010
- Macon, GA
Well i decided im going to find some d60's(at least a d44 front), and going to go full width. got the ok from my g/f that as long as i keep it low i can do it.
so im wanting to run leaves, tire size will prolly be 35's-37's. im only wanting about 4" lift over stock, and im going to cut the fenders to gain the rest of the clearance i need.
should i go with the shackle in the front so i can keep it low, or should i go with a shackle reversal set up? also i really liked my jeep with d60's and waggy springs in the front that extended my wheelbase, but didnt run them in the back...but i want to move the front axle forward about 2" and the rear about 2-4" and do a comp style cut. im stumped on which springs to go with. i want it soft for flex, but not so soft where it has bad street manners. next year ill be gettin a tow rig, so it wont be a dd all that much.
anybody have any suggestions?
i got a good source on some 60's out of a 79 ford, and i just started a new job, so ill have some $$ to get this project going. hopefully i can have everything ready to start by christmas time
, and access to all the tools i need, mig+argon, tig, arc, plasma cutters, torches, benders, notches(my buddy works at a fab type shop, just not automotive). i went f/w on my 95 yj i had and are doing it in my buddy's cj5. i just want to have a good setup for a little of everything, mud, rocks, trails, and some street usage, i wannt keep it low and clean fab work. the axles ill have access to are already set up for leaves, so if i kept my coil setup i would prolly go with XJ RELA's (radius arm style), and use maybe an eb spring. so the question is i saw jd makes upper buckets for the EB spring, so what would i do about lower mounts? where can i get those to weld on my axle? i dont like the EB bushing type radius arms, and i can get some re xj arms for next to nothing from a buddy. i guess i could use a poly performance uni track bar bracket and mod it however to keep the angles right.
