 - May 22, 2008
Coat hangers do work with car batteries, but it is meant as emergency or temp fixes. Just remember when you hook your batteries (if more than one) up in series then your adding your voltage together, when parallel, is the amperage is added. 3 batts in series=36 volts, 3 batteries in parralel= 900 cca. Someoen double check i might have it backwards, but important to know.
This is correct. Series affects Voltage, parallel affects current.
