i really wanted it tucked in as close as i could to keep my departure angle and reduce the chances of it getting damaged should i hit something head on.
the 2x2 is welded to the frame horns, the winch plate is welded to that bar front and rear. ill be adding some supports before i really put it to use. the 2x4 tube is welded to the front horns as well, planning to add some additional support for the ends back to the frame. i also wanna run two horizontal members in front of the winch to add some protection and mount the fairleader to that instead of the winch plate.
