- Sep 5, 2008
- '97
Got to the gym yesterday morning, pulled the key out of the ignition on my '97 B2300 manual transmission and the engine kept running. I pulled the fuel pump relay and went to do my work-out. I came out and pop-started it, went to work. When I got home I parked the truck downhill on the street and intended to troubleshoot but realized I'd lost my multimeter so I did what I could without it. When I short the posts on the solenoid with a screwdriver, the starter motor runs but the engine doesn't turn over. Since doing that effectively bypasses the starter control and ignition circuit, based on the Haynes manual wiring diagram, I assume this means that I have a discontinuity in the starter control circuit and/or a bad solenoid. I swapped out a bunch of relays in the engine compartment fusebox (driver side). There is no descriptive label on the cover and I have no owner's manual so I don't know which is the starter relay or if it's even in that area but every time I tried a new combination, I never heard the solenoid click so it doesn't seem as though the starter relay could be the problem. I pulled out the keylock cylinder and it is suspect because of the whole pull the key out keep running thing. The key lock cylinder seems to have alot of slop in it and I don't feel bad about $40 for a new one, however, I am suspecting my starter or a bad ground at the coil I've took a cursory look at all the grounds I can find but I guess I need to hand over hand all the wires and check all the connections but I'm assuming I'm getting at least some voltage to the post because the starter is running. I guess I don't know the ignition switch (in the steering column) or the clutch interlock switch is good either because I bypassed the control circuit by shorting the posts but I know I have a problem with the solenoid or starting circuit so I should start there. I have a habit of backing into parking spaces at the top of hills which has saved me for getting to work but I am due for u-joints and I cringe every time I shock the drivetrain like that...ha ha! Any other thoughts?
Thanks in advance.
Thanks in advance.
