pics of 1990 4.0
Deamers87ford
Lancaster, Pa
hey does anyone have pictures of their 1990 4.0 in a ranger i need to see how the wiring goes and how the fuel lines are ran
I am going to the u pull yard on tuesday (weather permitting) and if I see a 90 w/ a 4.0 in there I will snap some pics for you.
AJ
i will post but its a 91(same stuff though and its clean) right now
pics of 1990 4.0
side view
pics of 1990 4.0
front
pics of 1990 4.0
pics of 1990 4.0
if you want a pic farther back i can get one
Fuel lines run to the same spot that a 2.9 does. There are disconnects down behind the powersteering pump. They only go one way after that. As for the wiring, I took the entire harness from my donor truck and spliced in the taillights.
thanks so much could you take few pictures of the where the battery is and the relay on the fire wall please
yep i will, i have to go to wal mart and then ill upload some picks
[/QUOTE]Is that an original 4.0 or did you swap it in?[/QUOTE]
original
pics of 1990 4.0
pics of 1990 4.0
pics of 1990 4.0
pics of 1990 4.0
is that good?
few questions quick
green dot= do you have a wire on there
red dot= does this wire go to the starter
blue dot= what wires go to positive on battery
thanks
pics of 1990 4.0
